Is the Interface Dispenser Assembly (WR55X11092) critical for a GE Profile Refrigerator?
Brand: GE
Model Number: PFSS5RKZASS
Main Symptom: Display Board on Interface Dispenser Assembly (WR55X11092) may be fried
What happens & when: The interface is non-responsive.
Error Code (if any): Not available because display is non-responsive.
Parts or tests already tried: Dispenser door harness and connector is good.
The Interface Dispenser Assembly (WR55X11092) is no longer being manufactured.
I have been told that if the display board on the assembly is fried, the fridge is dead. However, this was not from an authoritative source.
Question 1: Is the Interface Dispenser Assembly (WR55X11092) critical for a GE Profile Refrigerator?
Question 2: How do I test the display board for correct operation?
Thanks!
If your refrigerator is still running and cooling, you may be ok. The only issue you may have is that you will not be able to adjust the temperature. However, they typically will start up on a default temperature. I don’t have a wiring diagram for your model. If the refrigerator will not run, then obviously you are going to have to find a board on eBay or another source, or replace the unit.
I guess you look under the left fresh food door hinge on the top of the door as there maybe a connection there?
31-9215.pdf (1.9 MB)
31-51810-2 GE PFSS5RKZASS Refrigerator Mini Manual.pdf (167.4 KB)
It is only running marginally. We have put dry ice in the fridge and freezer to maintain our food.
That could be a problem or maybe not.
I do have a wiring diagram for my fridge.
Can you direct me on the connector/pin combinations I should test with the voltage or ohms specs to see if the display board might still be good?
I bought the only NIB WR55X11092 display board I could find after 3 hours of searching.
I appreciate your help and will pursue any suggestions you have.
No, bottom left only. Top left next.
The WR55X11092 was fine. I probably should have followed up more promptly and asked more relevant questions. Perhaps this would have resulted in more productive process and successful outcome. In the end, I had a pro tech visit my home diagnose the problem almost immediately… a bad main control board. Ordered, installed, and working perfectly. Thanks for trying!
