Brand: Electrolux (Frigidaire)
Model Number: FMV156DC
Main Symptom: Won’t heat unless door pressed in and up
**What happens & when:**My Frigidaire FMV156DC microwave will only work when the door is pushed in and slightly up. The timer/display works fine. I removed/disassembled the door. Door latch is fine. If the unit works ok once door is pushed in could door switches be faulty? Or is it perhaps a misaligned door that is preventing the switches from engaging (it has no handle so we open by pulling on bottom of door)? Thanks.
