Vikas11111, it is likely that the compressor of the unit is having trouble starting up initially either from a winding weakening, the piston starting to get locked up, or the capacitor(if applicable) is the cause of failure. The three clicks are the relay opening and closing to provide voltage through the compressor circuit to get it started.
