Installed new Ice Maker and Optical Sensors and still not working
Brand: KitchenAid
Model Number: KSCS25FVBL00
Main Symptom: New Ice maker and or new optical sensors not working
What happens & when: nothing is happening
Error Code (if any): Still get two red flashes and pause for one second and repeats
Parts or tests already tried: Replaced old ice maker with WPL 2198597
Hello, check at the bottom freezer door hinge. There were several models that had issues with wires breaking at the bottom hinge. If the wires cannot be repaired, the entire freezer door would have to be replaced.
Checked wires at bottom of hinge. One wire may have been cracked so I repaired it still getting 2 blinking red status lights and ice maker still not working. Is there a way to reset ? I did try the jump start procedure and still nothing? What else could it be?
