Install dispenser assembly
how do I install this assembly ?
Remove the outer door panel by removing the two screws along the bottom of the panel. The entire thing will slide down enough to clear the control console and then can be pulled toward you. The dispenser is held in place by some screws and tabs that needs to be flexed to remove the dispenser. Put the new one in and the put it back together.
