Hello,
I’m trying to identify the correct replacement for an inline thermal fuse in my IKEA/Whirlpool wall oven, model IBS550PVS00.
After running the self-clean cycle, the oven lost all power. I’ve confirmed that the small inline thermal fuse near the electronic control board is open (OL on a multimeter). I’ve also replaced the rear thermal fuse (WP9759243), without restoring power.
The inline fuse is enclosed in a translucent protective sleeve, making its markings difficult to read without potentially damaging the assembly. It has two apparently identical female spade connectors.
I’ve found two relevant discussions on this forum:
- IBS550PWW00 — inline thermal fuse identification — reports Microtemp G4A01084C (84°C), with WPW10545291 identified as a replacement.
- IBS550PWS00 — self-clean failure — discusses a similar failure.
Whirlpool also issued Service Pointer W10645961, recommending repair kit W10625528 for this oven model. Unfortunately, the kit appears to be discontinued.
My questions:
- Can anyone confirm the correct replacement part number for the inline control-board thermal fuse in IBS550PVS00?
- Is WPW10545291 compatible with this model? What about WPW10638608?
- Does anyone have access to the component list or installation instructions for kit W10625528?
- If neither replacement is officially listed, can anyone verify the original fuse’s temperature, voltage, and current ratings?
I’d appreciate any information from technicians familiar with these Whirlpool-manufactured IKEA ovens.
Thank you!
