Brand: Kenmore Model Number: 79576209901 Main Symptom: Ice make water fill tube freezing up What happens & when: Water fill tube freezing up at end of tube right at end of tube above the ice cube tray
Error Code (if any):None
Parts or tests already tried: 3 different OEM LG water inlet valves (Part AJU55759303); New icemaker assembly; New compression water line from wall to new inlet valve; New bottom freezer door rubber gasket; Adjusting temp from 0 degrees to 2 to 3 to 4 to 5 over many different days and after unfreezing the water fill tube/line; re-covering up where line enters outside of the back of the fridge and enters into freezer. Literally EVERYTHING!!! The icemaker makes ice for 24-48 hours and then tip of fill tube freezes up again and again. Please, please, help before I junk the refrigerator. Thanks!
Hey there! First, don’t give up on that refrigerator just yet! I can certainly understand your frustration, especially after replacing three water inlet valves, the ice maker, the water supply line, and the freezer door gasket.
The good news is that you’ve already eliminated several possibilities, and there’s an important clue in what you’ve described.
Your ice maker works normally for 24–48 hours, but ice eventually forms right at the outlet of the fill tube, above the ice tray.
That makes me suspicious of a problem with the water delivery at the fill tube itself, rather than the ice maker assembly.
There are three possibilities I’d like to investigate:
Water splashing or wicking back onto the fill tube. If the water stream isn’t entering the ice maker’s fill cup cleanly, a small amount can remain on the tube opening and freeze after each fill.
A slow drip after the fill cycle. Even a tiny amount of water leaking past the inlet valve can gradually build an ice plug. Since you’ve replaced the valve three times, I’d also want to check for inadequate household water pressure or a restriction affecting valve operation.
A fill tube positioning or insulation problem. If the tube is too close to a cold surface, improperly positioned, or missing insulation around its opening, water remaining at the tip may freeze.
Here’s what I’d like you to check next
First, completely thaw the fill tube. Avoid using sharp tools or excessive heat, which can damage the plastic tube.
Next, inspect the tube’s outlet carefully. Make sure it’s pointing directly into the ice maker’s fill cup and that there isn’t any ice, mineral buildup, or damage changing the direction of the water stream.
Then, if you can safely observe a normal fill cycle, watch what happens when the water shuts off. We’re particularly interested in whether water continues dripping from the tube after the valve should have closed.
You can also check the household water pressure. LG-style refrigerator inlet valves commonly require at least approximately 20 psi, although I’d prefer to verify the specification for your exact model. Low or unstable pressure can interfere with proper valve shutoff.
One thing I would not recommend is continuing to raise the freezer temperature. A freezer temperature around 0°F is normal for ice production. The fill tube should be able to operate reliably at that temperature.
One model-specific part worth investigating
I checked the parts diagrams for your Kenmore 79576209901 and found something important: this refrigerator has a separate ice maker fill tube and fill tube grommet.
The parts listing identifies:
Fill tube: Original AJR73342301, with AJU73753101 listed as a replacement.
Fill tube grommet: 5006JJ2009A.
These are worth inspecting for damage, improper positioning, or gaps that allow cold air to reach water remaining inside the tube. I wouldn’t order either part until we confirm the problem.
Sears PartsDirect+1
Three questions that will help narrow this down
When the tube freezes, is the ice plug inside the last half-inch of the tube, or does ice build up around the outside of the tube and fill cup?
Have you checked the actual water pressure feeding the refrigerator, preferably with a pressure gauge? A new supply line doesn’t necessarily rule out low pressure from the house valve.
When you replaced the inlet valves, did you also replace the plastic fill tube running from the valve into the freezer, or is that still the original?
My next move would be to inspect the original fill tube and grommet, then verify water pressure and valve shutoff. I would not spend money on another inlet valve or ice maker yet.
If you can send a close-up photo of the frozen tube before thawing it, that would be especially helpful. The location and shape of the ice may tell us whether we’re dealing with dripping water, splashback, or a fill tube sealing problem.
This has been an ongoing issue for 4-5 years of the 7-8 of owning the fridge.
My townhome was built in 2001 and has had 3 different fridges. This Kenmore is the only one with ice making problems.
The last few years the problem was always where the ice cubes would clump together in the tray and sometimes not dump. That caused the tray to overfill and water would get into the tray and freeze most of the cubes together. I fought with that for at least 2 years. Eventually the ice maker itself stopped working at all and a new one had to be installed. The new one helped, but the same problem came back within a month. Sears parts direct sold me a new inlet valve that didn’t do anything different, so I returned it. They then sold me a Defrost Sensor that did nothing different. It was not easy to get at, so I installed it and left it and have the old one as a backup. The old one was not bad and tests good on the ohms reading on my multi-meter. I also was told that that part wouldn’t even cause my icemaker problem like a sears parts person told me may be the issue. I gave up for over a year and shut off the water and power to the icemaker and started making my own cubes. That got real old and I am now ready to fix it or replace the fridge. I decided to fix it…or try to. I am very unhappy with all the time I have invested and am still stuck with the same problem.
Fast forward to the past month and this time window is where 3 different inlet valves were replaced with no fix or different result. I already took the OEM water fill line/tube that goes from the inlet valve to the water fill cup and soaked it in warm water for about 8 hours in my kitchen sink. I put all sorts of water through it, including blowing water and air through my mouth, with no problems having water easily pass through the tube. Not a spec of dirt or debris came out, nor was dirt/debri in the warm, lightly dawn dish soaped, water in the sink from soaking.
The water pressure in my townhome is not the problem unless there is too much pressure. I can pull the water fill tube out of the freezer and hit the cycle/reset button on the icemaker assembly and watch the water come out into a bucket or the icemaker catch pan and see that the water is a steady stream. It isn’t even close to a drip. I could probably shoot someone with the water 5-10 feet away if I tried. As said before, the water pressure was not a problem with the other fridges or this fridge for the first 4-5 years.
I also took a hair dryer (1st time today from the back of the fridge) and blew warm air through the conduit that the water fill tube slides into. I was careful and kept the hair dryer several inches away from the conduit to ensure it would not get to hot or melt. The ice cube catching tray was empty and dry and under the opening to catch anything that was blown through with the hair dryer. Nothing came out or was in the ice cube tray or cube catch pan.
The water supply tube is the OEM tube and has never been replaced. It only freezes up on the last 1/2 inch. An ice pellet maybe the length of a pencil eraser right at the end of the fill tube where it goes into the icemaker cup/water diverter is where it freezes. Unfortunately that little ice pellet is solid enough to not give without defrosting or applying heat. If I pull the fill tube out of the back of the freezer and warm it up for 30 seconds, the pellet easily comes out. Or, leave the tube out and come back a few hours later and the ice pellet will be gone and I can verify by hitting the reset button on the icemaker and watch the water shoot into a bucket or verify it filled the icecube tray on the icemaker. That will freeze and dump the cubes a few cycles up to 2 days max and then the libe id frozen again.
I highly doubt that my water pressure is too weak. If anything it is too strong. But how would that happen when from 2001 to 2021 there was never a problem with water pressure and ice cube making? No plumbing was worked on.
Thanks for your detailed response and for the fast turn around of your reply. You suprised me with how thorough you were vs Sears Parts Direct insisting I needed more parts or to pay for a tech to come out. They had no option to talk to or message a single person who has any background in actually servicing this issue at an installer or service tech level. I doubt I will ever buy anything from Sears again in my life and am starting to feel the same about LG/Kenmore.
Thank you for taking the time to explain everything you’ve been through with this refrigerator. I can certainly understand your frustration, especially after replacing multiple parts and spending years trying to solve the same problem. You’ve already done quite a bit of troubleshooting, and the details you’ve provided are extremely helpful.
The good news is that I think we’re getting closer to identifying what’s actually happening. The fact that only the last 1/2 inch of the fill tube freezes is an important clue. It suggests that a small amount of water may be remaining at the end of the tube after each fill cycle, eventually freezing and blocking the next fill.
Since you’ve already replaced the inlet valve three times, replaced the ice maker, cleaned the original fill tube, and confirmed that water flows strongly during a manual fill, I wouldn’t recommend buying another valve or ice maker at this point.
There are three things I’d like to investigate before considering any more parts.
First, let’s check for water remaining at the end of the fill tube. After thawing the tube, run a manual ice maker cycle and watch the water enter the fill cup. Once the valve shuts off, look closely at the end of the tube. Does the water stop cleanly, or does a small droplet form and remain there? Even a small amount of water left at the tip can freeze over several cycles. If possible, check again a few minutes later for any additional dripping.
Second, let’s check the fill tube’s position. Because this is the original tube and the problem developed after several years, I’m wondering whether its position has changed slightly or whether the end has become distorted. Make sure the tube is properly seated, aimed into the fill cup, and not extending farther into the freezer than intended. Also, inspect the end for cracks, deformation, or mineral deposits. A small change in the tube’s position could allow water to remain at the tip instead of draining completely into the ice maker.
There’s one other detail I don’t want to overlook. You mentioned that the original problem involved ice cubes clumping together and water apparently overfilling the ice maker. That could indicate a separate issue with the ice maker’s fill volume, water splashing, or cubes not releasing properly. I wouldn’t automatically assume that the earlier clumping problem and the current frozen fill tube have exactly the same cause.
Here’s what I’d really like to know next:
When you run a manual fill cycle, does the water enter the ice maker’s fill cup cleanly, or does any water splash outside it?
When the water shuts off, does a droplet remain hanging from the end of the fill tube?
When you remove the frozen tube, is the ice pellet entirely inside the tube, or is there also ice forming around the outside of its tip?
Those answers should help us narrow this down considerably.
One final thought: because the blockage consistently occurs at the very end of the tube, I’d also like to consider whether the fill tube is being exposed to unusually cold air or whether the original tube’s positioning is allowing water to collect at its outlet. Depending on what we find, correcting that condition may be more effective than replacing another electrical component.
You’ve already invested enough time and money in this repair. My goal now would be to identify the cause through testing, not continue replacing parts and hoping one works. I wouldn’t give up on the refrigerator just yet. Let’s see what these observations tell us before spending another dollar.
