Ice maker Fill Tube drips water than freezes up
The ice maker fill tube drips a small amount of water over time and eventually freezes up. This causes the unit to stop making ice. I have tried to defrost the frozen fill tube with a hand held steamer and the ice maker will work for a few cycles but the fill tube will freeze again. I have actually seen droplets of water run down the fill tube after the ice maker had finished dispensing water to the ice tray. I suspect the problem might be a faulty water valve. Please help! Thank you.
Please respond my question! Thank you.
Hi.
You need to replace the water inlet valve
AP3044061
Here are the breakdown diagrams and Cabinet parts for Whirlpool KSSP36QJS00 - AppliancePartsPros.com
Please, post the results.
Simon.
Ice maker fill leaking when retrieving water
