Brand:LG Model Number:LRSxC2306S/01 Main Symptom: no water to ice maker What happens & when: replaced ice maker assembly appears to function mechanically but no water flow
A
If you get water to the front door dispenser, then the water filter and housing are good. Water goes through the filter for the front dispenser and the icemaker. If it just the water supply to the icemaker that is not working, I would replace the inlet valve assembly.
