I would like an ice maker wiring diagram available for Frigidaire model FRS6LF7FM0
Brand:fRIGIDAIRE
Model Number:
Main Symptom:
The following link can be used to view the wiring diagram for this model. From what I can identify, there should be four wires going to the ice maker. There should be a black wire with 120 Volts AC from the power supply cord, a light blue wire for the neutral, a yellow wire that would be used to send voltage to the ice maker water valve, and a green wire with yellow stripe for the ground wire. Parts for Frigidaire FRS6LF7FM0: 23 - Wiring Diagram Parts - AppliancePartsPros.com
