I’m having filling and draining issues with my GE dishwasher
Brand:GE
Model Number: DDT700SSN5SS
Main Symptom:Dishwasher will stop mid-cycle or stop at the beginning of a cycle.
What happens & when: after stopping dishwasher will beep and display will show H2O or Fdt
Error Code (if any):H2O or Fdt
Parts or tests already tried: I have checked both the water line and drain line, they are not clogged. I have cleaned the 2 drain filters. I looked for a flood float but I believe this middle uses a sensor not a physical float.
Test to see if there is 120 vac getting to the water valve when it is supposed to fill. If there is voltage but no water coming in then this will be a faulty water valve.
