I have had it with Sears NOW
Someone help please.
I have a CrapNmore dishwasher. I replaced one almost 2 years ago because the control panel went bad, and I did not want to take the chance in getting into a sorted mile long parts order scenario to rule out… NOW, the new dishwasher (less than 2 years old), is not working. All I did was reset the bastard to do some base cabinetry repairs.!!! Apparently they are sensitive, as in dont even look at it…
Symptoms, first wife said all she could get was normal cycle. I said no, you didn’t press that crappy little button pad correctly, and it worked right. Next day, NOTHING, no lights, no button response. So I am guessing another control panel is bad. One note is that she did point out that it no longer makes a “click” sound when unpluged and plugged back in?!!? For whatever thats worth.
I am savvy enough that if anyone here has any suggestions, and even inclusive of some soldering on the board, I am up for it. I just dont know where to start with all the circuitry. Any help greatly appreciated…:slight_smile:
[quote=bbc3;338582]Someone help please.
I am savvy enough that if anyone here has any suggestions, and even inclusive of some soldering on the board, I am up for it. I just dont know where to start with all the circuitry. Any help greatly appreciated…:)[/quote]
BBC,
Here’s a couple of checks to make,
Check and make sure you have 120 VAC at the junction box on the lower frame, behind the lower kick plate / access panel.
You’ll need to access the control board and control panel, and other components.
visually inspect the thermal fuse, and control board, if you have a multi meter, check the fuse for a closed circuit,
AP3115186
Next, check the door switch assembly, switches and wiring for circuits,and damage.
AP3103581
I don’t think you’ll need a control board, but ,
Disconnect the touch pad ribbon from the control board, clean the insertion end of the ribbon tracer with alcohol, I do the same on the connector on the control board, be careful, once the ribbon is dry, make sure you insert it tightly into the board connector.
The control board would be the last resort,
If all checks are OK, replace the control panel key pad assembly, first,
AP6013464
Thanks for the most informative post. I will feedback when completed.:slight_smile:
[quote=Joe / APP Team;339323]BBC,
AP3115186
AP3103581
AP6013464
:slight_smile: :slight_smile: :)[/quote]
BBC,
Great,
Will keep an eye out for your post.
My digital ohm meter reads “1” when the leads are separated. I think I recall that to be infinite or open. When I apply the leads to the thermal fuse it remains at “1”. A quick test of the meter leads togther quickly “zeros it out”. So if my basic knowledge of fuses ( and I think you called it a fuse) stands, there is no circuit accross there, which means no signal or electricity can pass correctly. Am I on target.?? Or is this more a a resistor that I need to use more refined settings on my meter for.??
If The part needs replacing, can I jump around it in the meanwhile? Is it merely a capacitor, or resistor??
[quote=Joe / APP Team;340764]BBC,
Great,
Further I am thinking this a is thermal cutoff type breaker (as you probably said:D ) and trying to discern the identity of it. I am guessing by the number on the side it is(TF 098C) a 98 degree celc. temp rated.
So the question remains, is the basic open or closed circuit test valid. I apologize as the way you worded what to check for was unclear to my interpretation. I read another post where the guy said his meter went to 1.5 ( analoge assuming). So recalling, they close down from infinited in descending. His was ok, so it would have remained at high number i guess if not. Same as “1” on my digital one… Sorry so long just trying to get it…:slight_smile:
Further, I think I am on target. I am also guessing I dont need to run it without the breaker in line as something caused it to overheat. Could be just a cumulative time bomb DESiGNED by Whirpool/sears.. I am pretty sure. I’ll be that was the damn problem with my last board. Too bad I was not here for that one. It was a gas range before and thats 2WICE you guys bailed me out..!!I cant tell you guys how helpful you have been.
Thanks a bunch Joe…!!!
[quote=bbc3;340856]My digital ohm meter reads “1” when the leads are separated. I think I recall that to be infinite or open. When I apply the leads to the thermal fuse it remains at “1”. A quick test of the meter leads togther quickly “zeros it out”. So if my basic knowledge of fuses ( and I think you called it a fuse) stands, there is no circuit accross there, which means no signal or electricity can pass correctly. Am I on target.?? Or is this more a a resistor that I need to use more refined settings on my meter for.??
If The part needs replacing, can I jump around it in the meanwhile? Is it merely a capacitor, or resistor??[/quote]
[quote=bbc3;340862]Further I am thinking this a is thermal cutoff type breaker (as you probably said:D ) and trying to discern the identity of it. I am guessing by the number on the side it is(TF 098C) a 98 degree celc. temp rated.
Thanks a bunch Joe…!!![/quote]
BBC,
Not only are you on target, it’s a Bullseye.
As for bypassing the fuse,
It is a “safety” device, it can be done for testing purposes, but that should be the limit. But you decide, safety or convenience.
Remeber,
Check and make sure all the wire connections are tight,especially at the junction box, and the new fuse.
You have a 3 prong, polarized, grounded outlet, with at least 105 VAC when the dishwasher is running, and a 3 prong power cord.
Thanks,
So now I am gonna give back a little. The repairs went :slight_smile: well but I have a few notes of advice to offer…
  1. When dealling with a disassembled dishwasher, DONT screw the door opening lever in prior to putting on the inside wall panel (water side). BECAUSE, when you let it spring/slam shut, just as you are figuring out that the handle mounts underneath the inside plastic panel (nice test), the metal mechanism will go in too far locking the door closed creating a puzzle box with no entry:eek: ..
Second, if you are a crafty one and try to replace the temperature breaker yourself, DONT SOLDER IT. Its temperature sensitive… DUH. Actually I did not make that mistake thanks to the electronics shop owner… It comes with 2 aluminum sleeves for crimping. At any rate, the 10$ part (available here)may be worth the order if you can wait…:slight_smile:
It works great so thanks again. What really disturbs me is that I have no doubt in my mind that this is what was wrong with my last model, and this is by design. So essentially the auto parts war of the 70s is reborn by WHIRLPOOL themselves. AND I bought a dishwasher FOR NOTHING last time…:frowning: But not again. Thanks/.
[quote=Joe / APP Team;340905]BBC,
Remeber,
Thanks,
[quote=bbc3;341110]So now I am gonna give back a little. The repairs went :slight_smile: well but I have a few notes of advice to offer…
It works great so thanks again. What really disturbs me is that I have no doubt in my mind that this is what was wrong with my last model, and this is by design. So essentially the auto parts war of the 70s is reborn by WHIRLPOOL themselves. AND I bought a dishwasher FOR NOTHING last time…:frowning: But not again. Thanks/.[/quote]
BBC,
Thanks for the update, and your observation information.
Great job,
We’re happy that you’re happy,
Contact APP Repair Forum anytime, there’s always someone here who can help.
Hello all,
Hope all is well with everyone. Seems my problems are not so easily resolved. The thermal fuse has blown 3 times now since I resolved the problem at the time of the last post here. So the issue seems to be, what is causing the thermal fuse to blow?
(1) I dont think there are any dwelling/house electrical issues contributing. I am getting about 118volts A/C at the outlet. One note is that it is an outlet on the same house breaker with other outlets in line. I believe the vacuum cleaner may even be run from time to time in this circuit. Was not thinking that was related though, as this is a “thermal” fuse.
(2) I have been using the “sani-rinse” which I believe heats the water pretty good in an extended rinse cylce. I am going to try to stop using that cycle and see if it helps. But really, shouldn’t I be able to use it? So is it a programming problem on the main board chip??
Possible solutions: I was thinking maybe slightly insulate the thermal fuse to give some buffer. Or even get a fuse with a higher temp. This one is 90 Celcius, which I believe converts to 210 degrees F, or right below boiling. So perhaps get the next one up? Seems like while it would allow for too much heat potentially, it would still shut it down prior to total meltdown?!?
Any thoughts greatly appreciated. Joe?
Thanks in advance.
[quote=bbc3;364912]Hello all,
Thanks in advance.[/quote]
BBc,
I’m wanderring, myself.
You’re sure you got all the wires connected and the connections are tight, correct ?
And you did use the harness that came with the fuse, correct ?
I"m sure you’ ve checked for proper polarity at the junction box, on the frame,
You’re pretty close to target on your temperatures,
Sani Rinse will heat the water to 155 dgrs.
High limit thermostat is rated at 180 dgrs.
The thermal fuse is rated at 195 dgrs.
(give a 10% “fudge factor” either way, and you’d still be in factory specs).
You should probably check the resistance on your heater element.
10 to 30 ohms resitsnce at room temperature, element cold.
in the dry cycle, with the element dry and on, you should read approximately 25 ohms after th element is on for a while.
The 118 VAC, is in a proper range, as long as the motor is running or the heater is on.
With the heater on and the motor running(sani rinse cycle) at 118 VAC, you should be drawing 5.5 to 6.5 amps. You should also check the voltage at the same time.
I can only think of a couple of possibilities,
Possibly, a sticky thermostat, weak thermistor or a low voltage problem, causing a higher than proper amperage draw.
For safety sake, don’t insulate the thermal fuse, or run the unit without it, other than to test the unit, There is a great possibility of a fire hazard.
:confused: :confused: :confused:
When you say polarity at the box, you are talking black to black, and white to white where the cord to the wall is capped in, right. The little metal box under the front right that houses the wires connecting to the power supply I am assuming???
Funny though I am not sure there is not a dwelling issue here. It seems like once I was changing a hanging light and I had the switch off, the black was def cold, but then I got lit up by the common line (white), but mildly it seemed. So now I am really wondering where to even start… as I wonder if there is a whole house issue somewhere. It is an early sixties home… I am not so sure that one of the runs has not been reversed somewhere in the attic or underneath. I DO KNOW that all the lines in the breaker box are correct as I did replace that and have it certified… But this does not rule out a swap somewhere at a modified juction someone may have done at some time… Dont know just thinking aloud. It may even require something being plugged in or energized somewhere to create the conditions. It was just too much of a mystery so I did not pursue it. I really dont think its the issue.
Can I even rule out. I can remember if I can even see poles in terms of A/C, white/black, etc…
[quote=Joe / APP Team;365908]BBc,
:confused: :confused: :confused:[/quote]
[quote=bbc3;366022]When you say polarity at the box, you are talking black to black, and white to white where the cord to the wall is capped in, right. The little metal box under the front right that houses the wires connecting to the power supply I am assuming???
Can I even rule out. I can remember if I can even see poles in terms of A/C, white/black, etc…[/quote]
BBC,
We’re getting off track,
But,
If that light you were working on, is a “dual” switch system, A light switch on each side of the room, that can happen, that system controls the neutral leg of the light circuit, not the hot leg, otherwise you do have a problem.
Now for the dishwasher,
If I remember, you’re using a power cord and the unit is plugged into an outlet, with the rest of the kitchen outlets?
These should be 120 Volt, polarized and grounded outlets.
(you could purchase a polarity test meter to check, or use your multi meter.
(the center/ bottom round opening is ground, the left side slot should be L1(hot leg) and left slot N (no voltage).
(but, it’s been working fine until now ???)
Check and make sure the hot leg on the power cord, is attached to the Black wire in the junction box on the dishwasher, and make sure the connections are really tight and the white and green wires, are proper and tight as well.
You can also insert your meter probes into the slots on the other “socket” and test the voltage , while the dishwasher is running, we can varify if there is too deep a voltage drop(no more than a 10% drop in VAC under a load).
Your idea, running the unit with the heater circuit eliminated, will give us a better idea as to possible problems as well.
:cool: :cool: :cool:
You know, I was posting about a fridge today and just thought I woudl provide some feedback on this thread for the sake of answering the issue and for data’s sake. I never got the part to stop blowing. I think it was a heat delay fuse. So I had to wire around it. I just dont run the unit when I am not present. But it has to be a failure in the firmware/hardware on the main board I am guessing. But there was not fix I found and I am not about to crank out a hundo on a three hundred dollar dishwasher..
So thanks for all the help. It gets the job done for now..:slight_smile:
[quote=bbc3;517742]You know, I was posting about a fridge today and just thought I woudl provide some feedback on this thread for the sake of answering the issue and for data’s sake. I never got the part to stop blowing. I think it was a heat delay fuse. So I had to wire around it. I just dont run the unit when I am not present. But it has to be a failure in the firmware/hardware on the main board I am guessing. But there was not fix I found and I am not about to crank out a hundo on a three hundred dollar dishwasher..
So thanks for all the help. It gets the job done for now..:)[/quote]
BBC,
Sorry we couldn’t get you up and running"properly". We understand the frustration.
Good Luck,
