I have a Maytag MVWC200XW1 washer stuck on sensing
Brand:Maytag
Model Number:MVWC200XW1
Main Symptom:Stuck on Sensing
What happens & when:The light is not flashing and diagnostic does nothing.
Does that Sensing light come on immediately even after power cycling the washer for a couple of minutes by unplugging it or turning it off at the breaker? If it doesn’t, will the washer let you into diagnostic mode but just doesn’t allow anything to be activated?
