I have a Kenmore dishwasher model 665.13222N413. The wires are broken at the electrical connector for the water inlet valve. Is there a way to open the electrical connector to reinsert the wires?
Brand: Kenmore
Model Number:665.13222N413
Main Symptom: Broken Wires at the Water Inlet Valve
What happens & when: Valve doesn’t allow water to enter the machine.
Dishwasher will complete the entire cycle but no water enters the machine due to broken wires at the water inlet valve.
Yes! On your Kenmore dishwasher model 665.13222N413, it may be possible to reinstall the wires into the water inlet valve’s electrical connector, depending on how the wires broke.
The important thing is that the wires must be securely attached to their metal terminals inside the connector. Simply pushing bare wires back into the plastic connector won’t provide a safe, reliable connection.
Here’s what I recommend
  1. Turn off the dishwasher’s circuit breaker before working on the wiring. Verify that power is off.
  2. Disconnect the electrical connector from the water inlet valve.
  3. Look closely at the connector for a small locking tab or removable plastic retainer.
  4. If the connector has removable terminals, you may be able to release them using a small terminal-release tool or precision screwdriver.
  5. If the wires have broken off flush with the metal terminals, you’ll need to replace or properly re-crimp those terminals. You cannot simply push the wires back into place.
If the plastic connector is damaged, melted, or its terminals are loose, I recommend replacing the connector with a properly rated repair pigtail rather than trying to reuse it.
I checked the parts listings for your exact model, and the water inlet valve is listed as W11175771. However, I couldn’t confirm a separately available repair connector or its exact release mechanism.
eReplacement Parts+1
One question: Did the wires break off right where they enter the plastic connector, or are there still short pieces of wire sticking out?
If you can upload a close-up picture of the connector, preferably showing both sides, I can help you determine whether the terminals can be released and reused or whether the connector needs replacement.
Thank you for your reply. The wires broke very close to the connector, maybe 3/16 to 1/4" ( too close for any type of butt splice ). Since I thought it was too difficult to unseat the wires in the connector, I soldered the wires and covered with heat shrink. My dishwasher is working fine now.
