I cracked my frigidaire cooktop- help please
I cracked the cooktop and a piece broke off the corner. I have pulled the entire unit out about 6" from the wall and was able to remove the control panel in an attempt to see how the top is held on and to see if this is a job I want to tackle.
I am ready to do this myself if I can get some fairly detailed instructions on removing the cooktop and ordering a replacement (plus any other parts like clips or gaskets needed).
Any help is greatly appreciated. Thanks, Dave
open the door to the stove there are two screws under the top remove the screws and lift the top there are two hing hooks it should come off easy but putting back can take a little time becouse of the hing hooks
Are you sure? Mine has 4 screws???
Anybody else out there with any more detailed directions would be appreciated.
