Brand:jenmore
Model Number:11082891120
Main Symptom:doesnt fit it is too long a quarte
What happens & when:when i try to install the new gear after install the clutch
Parts or tests already tried:yes
Hi can you please provide the part number you purchased to narrow it down please.
3360629
i did everything according to video
but the problem is after installing the clutch the bolts of the gear doest touch the base so i cant adjust
Hi, if the three 1/2-inch gearcase mounting bolts aren’t reaching the metal frame, that usually means the transmission isn’t sliding all the way into position. Since you just replaced the clutch, something may be slightly out of alignment.
I would start by checking the clutch assembly to make sure it’s installed correctly and seated all the way. Next, check the brake cam and make sure it’s properly aligned with the clutch spring.
Also, inspect the transmission shaft and the opening in the spin tube for anything that might be preventing the shaft from sliding all the way in.
You may need to lower the transmission slightly, realign everything, and gently rotate the shaft while pushing the transmission back into position.
Don’t try to force the bolts to pull the transmission into place, because you could damage the mounting threads or other components.
Once everything is properly aligned, the transmission should sit flush against the frame, allowing all three bolts to thread in normally.
i did everything again and still doesnt fit in i measure the old gear with the new one and the new one the diffrerenvce is clear the new one is longer
this is the part number that is called for your model.can you see a part number on your old part ?
Whirlpool Washer Gear Case 3360629
