How do I remove the Motor from the Sump? Any screws or clips? i tried turning the moter & could not get it to budge. Thanks.
There is a 3/8" bolt on the right side of the motor between the sump & motor, you’ll need an extention to get it. Then the sump turns counter clockwise to remove.
Thanks, steve.
Hope that’ll help you out some
Nat
