I need some guidance in removing/replacing the door balance link. Any help would be greatly appreciated!
You mean the rope link that runs through the pulley and hooks on the spring ? If that is what you are referring to I would replace both at the same time, not just one. I usually pull the dishwasher out about 8" so I can get to the rear spring easier.
