It seems easy enough to replace couplings on other models. HOW do you replace coupling on model # KSB560
[quote=tjndesigns;235113]I wasn’t able to remove it using the instructions posted (i.e. prying up the adapter with the screwdriver while turning). Maybe I just don’t have the finese. There are flats on the shaft under the nut that you can hold on to. I cut a 7mm slot in a thin piece of metal and and held it from turning with that. Could also be done by sacrificing a 7mm open-end wrench and grinding it down if necessary.[/quote]
Don’t even try the pry off method to remove the old coupler because there is a major risk that you will damage or scratch the blender housing. I used two thin metal slats to hold the flats on the shaft - keep in mind the coupler is reverse threaded - and it came right off. The whole repair took less than 10 minutes. Appliance Parts Pros rocks!
I have the same issue - how do you replace the coupling on the KBS560MC0 model? It’s a different type of coupling - female to male.
I am not a repair-gifted person. But I was damned if I was going to shell out $$$ for a new blender when a $13 repair was possible. After reading the PDF instructions, I was able to remove the coupling! I just used patience and a strong flat head screw driver. With multiple “lifts” using the screwdriver (and I also put a towel underneath it so as not to dent the plastic on the blender base) I finally got it off. Below was a beautiful threaded shaft. If I can do it, you can too!! ![]()
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
I got it off now I hope I can get it on when the new one arrives
[quote=Adam / APP Team;221463]Stepup,
Some of the parts are the same. I will help you out in getting the correct part. What part are you looking for?[/quote]
I have the same issue. Can I order the coupling for the ksb5ww4 to fix my ksb5ww3 ? thanks-katycal
[quote=Liguori;60176][SIZE=3][COLOR=#000000][FONT=Times New Roman]Instruction Sheet for KitchenAid Blender Coupling Drive Installation[/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]1)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Unplug Blender[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]2)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]With blender facing you, insert flat blade screwdriver (3/8 to 7/16 inch) between the black coupling drive and the blender housing.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]3)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Raise up on the screwdriver to turn the coupling drive clockwise (it is a left hand thread so the coupler keeps tight during use). Keep making ¼ turns until the coupling drive comes off. Do not worry about bending the old coupling drive. You are going to throw it away.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]4)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]There is a flat spot on the blender shaft and construction of a flat tool is possible, but not necessary.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]5)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Check the threads on the blender shaft and clean the old metal shavings from the threads. Hand tighten the new coupling drive. It will be kept tight during normal use due to the left hand thread design and the clockwise spinning of the blades.[/COLOR][/SIZE][/FONT][/quote]
Thanks Liguori
The Flat spot was deceiving to me, it implied a pressed on part so I thought I had a “unique” issue that nobody had seen. The flat spot is now obviously an area for locking the shaft with some special tool (I did not use such a tool). I did EXACTLY as you prescribed a large flat head forcing the metal disk (the remnants of the drive coupling) CLOCKWISE and upward in small increments, maybe 8 times, and voila, cleaned the threads with an xacto knife and I am in business…THANKS!!!
Same Question Here! Help!!
We finally figured out how to change the coupling on the [MODEL]ksb580cr0[/MODEL] model!
- Remove the bottom of the blender by taking off the feet cushions and loosening the screws.
- There is a long cylindrical piece of metal that runs all the way through the motor and sticks out a little in the middle of the fan. While using vise grips to hold the current coupling in place, use a flat headed screw driver to turn the metal piece to the right (if you’re looking at the bottom of the blender).
- This should release the coupling. Then unscrew the coupling to remove it.
- Screw the new coupling in and put the bottom the blender back on.
Hope that helps!
Hello everyone! We thought this would be some helpful information for anyone trying to install the blender coupling. Here is the difference in the two coupling installs. You will need to open the attached file for the style of coupling you are replacing. Hope this helps.
If you are installing the W10279256 or AP4500686, you will need to follow these instructions.
AP6018469
BLENDER SERVICE MANUAL COUPLING W10279256.pdf (101.7 KB)
If you are installing 9704230 or AP2930430, you will need to follow these instructions. We hope this will help you with the installation of these two parts. Thank you for your business with AppliancePartsPros.com! Good Luck!!
AP6013694
9704230_Instructions.pdf (52.3 KB)
Just a quick note to let everyone know that we now have a short video clip showing exactly how to remove and replace the KitchenAid blender coupling:
[QUOTE=carrieswan24;542445]We finally figured out how to change the coupling on the [MODEL]ksb580cr0[/MODEL] model!
Hope that helps![/QUOTE]
I tried this method and the metal bar with the flathead opening on the bottom will NOT budge. I also tried the method in the video by giving the coupler a wack in a clockwise direction.. I can get it it to spin, but it doesn’t unscrew. Does anyone have any other ideas/methods for the KBS560 series blenders? I spent nearly two hours trying to get the coupler off and am tempted to throw in the towel and buy a new blender.
Thanks in advance!
[QUOTE=;][/QUOTE]
Visiting a Chicago bakery to pick out your wedding cake is a task that often gets both the bride and groom excited�especially when tasting is involved,maternity dresses! Tip: Make sure whatever bakery you order from allows you to taste a sample of the same type of cake and icing you are ordering. Because no matter how beautiful the cake is, if nobody is able to stomach it, you will have succeeded in wasting a ton of money and leaving behind an impression you never wished to make,evening dresses for weddings!Several Chicago wedding cake providers are listed below,shapewear, but this is only a sampling of what the city has to offer. You should do an online search or peruse the phone book for more pastry chefs in your area. Your budget may also help you narrow down the pool.Creative Cakes (708-614-9755; www.realbuttercream.com)For detail-oriented pastry chefs who will create the cake of your dreams, you may find Creative Cakes is the only way to go. See their online portfolio to get a feel for previous work, which focuses on decadent masterpieces comprised primarily with real butter cream icing. The store is owned and operated by two sisters,black cocktail dresses, Becky and Beth. Together, they possess over fifteen years in the cake decorating business. For more information,strapless bridesmaid dresses, email info@realbuttercream.com, or visit their website and check out their designs.Bake For Me! (312-957-1994; www.bakeforme.com)Bake For Me,mothers of bride dresses! has been in business in Illinois for over the past fifteen years, providing tiered wedding cakes that really make a splash. They offer a wide assortment of toppings, icings, fillings, and designs,wedding wraps, which makes them one of the more prominent bakeries in the Chicago area. Contact them for a taste sampling session and let their experience work for you. Fill out a form online for your free consultation.Piece-A-Cake Bakery (847-836-6703; www.piece-a-cake-bakery.com)Located in the heart of Illinois,affordable bridesmaid dresses, Piece-A-Cake has been around for a while�dazzling their customer with their innovational and unique designs. Their portfolio features delicious-looking novelty cakes, �fantasy� cakes, and traditional options. They can recreate an old pattern or make you something completely fresh and new. Email pieceacakebakery@aol.com to arrange a consultation including a cake tasting.La France Bakery (773-737-2113; www.lafrance-bakery.com)For all the icing swirls and flowers you could picture,bridal necklaces, La France can give you more. Their wedding cakes are traditional and elegant�just schedule a consultation to see what this Chicago-based bakery can whip up for you. La France is located on Kedzie Ave in downtown Chicago. Call ahead to set up your own cake consultation.Arlington Cake Box (847-255-9120; www.arlingtoncakebox.com)Arlington�s Cake Box wedding cakes are crafted with experience�a combined 100 years! Their portfolio includes freshly baked to and original scratch recipes. Situated in the northwest suburbs of Chicago,blue bridesmaid dresses, and family-owned since 1949, it is a prime choice for the bride who wants something exquisite. You can request a tasting consultation by calling them at the telephone number above.LINKS: elegant bridal sleepwear Interfaith officiant
[QUOTE=pikabb;660081]Hi,
Thanks in advance![/QUOTE]
Same problem here and the appliance parts phone person was no help at all. Told me to watch the video. Thanks. Pretty annoying especially since I just bought a new canister along with the coupler. I have spent way too much time trying to get the part off. On my way to buy a new blender.
Nice info shared.
same here.
hope to get more ideas, thanks.
- Pry the old coupling off of the motor spindle.
- Clean up the blender motor spindle.
- Install the new blender coupling.
Thank you so much here.
