How to lift up a ceramic cooktop in a slide in Jenn air downdraft Model JES9900BAB
Brand:Jenn Air
Model Number: JES9900BAB
Main Symptom: Large element does not heat
What happens & when: How do I left up slide in surface to replace
With the power supply turned off and the vent grill removed, there should be screws on the inner lip of the vent section that would need to be removed. There will also be screws along the bottom of the front console that will need to be removed, along with screws along the sides. Once all screws are removed, the cooktop should be able to lift up.
