How to install maytag replacement motor 12002351 in a a209 washer without a blue wire
Brand: Maytag
Model Number:A209
Main Symptom: how to wire replacement motor with a blue wire and no green wire
What happens & when: wiring
The video on our site is showing the process for a 2-speed washer and yours is a 1-speed. According to the installation instructions, which I’ve attached below, you can ignore the extra wires if you’re working on a 1-speed unit. The original green ground wire should be transferred to the new motor.
instructionsheet-16023044 (1).pdf (1.2 MB)
