How to install bottom door cam part wpw10329686 on hinge wp2208137 on my kscs25fkss02 kitchenaid frig? The hinge has a circular T shaped thing that holds the cam to the hinge. The cam will not fit over the circular permanent T shaped thing
Brand:Kitchenaid
Model Number:kscs25fkss02
Main Symptom: door did not swing close
What happens & when:Replacing both cams but cannot install the one that goes on the hinge itself
According to the manufacturer that is going to be a tight fit on the hinge, it may need some grease or other lubricant to get it on there.
The cam is hard plastic There is no way that it is going to fit over the machined pin that is wider at the top. Other models have a bolt or screw that hold the cam to the hinge. Your web site references screw #59440 as also needed. Maybe that could be used if the machined pin could be removed.
Ah, that’s what you were referring to. That pin will need to be removed, either by knocking it out with a punch or drilling it out.
