How to clean dust inside maytag yedz400tq
Hi. I would like to know if it’s possible to clean the dust and all that are laying on the interior plate of the dryer. if I look through the dust collector , I can see quite a bit of dust , a screw driver bit , a broken pencil… .
my gl is telling me it takes more time for the clothes to dry now.
how would you address this problem plz ?
this model seems to have the lower section that could maybe be open; is this the case ? and will it give me access for cleaning ?
the dryer and washer are enclosed in a custom space , so I would really prefer not to pull out the units.
thanks for your help
stef
I assume you mean you can see debris where the filter slides in?
Good news the inner plastic grille comes off with 2 screws (maybe 3) and you may be able to reach the area with a vacuum attachment of even by hand. Watch for sharp edges. Screws are inside the drum pointing toward the front going through the grille.
But for further access yes that bottom section of the front does come off, a few screws under bottom edge. That’s give you access to the interior of the cabinet but not into the blower duct where the filter sits. For that area you need to pull the silver duct off that’ll be behind the lower access panel.
I think you can access all the necessary screws to remove the duct from behind the access panel and just vacuum it out.
This video of the element change may help you visualize the task better. You’ll see the blower duct at about 5:15-30. It’s the silver piece with the gold colored screws. I don’t think you’ll have to take the top, front, etc off. Just the 3 gold screws that hold the duct onto the bulkhead and it’ll slide down enough to come out without any further disassembly than the access panel. The filter will need to be out to remove duct, and the unit should definitely be unplugged or breaker opened for safety.
Whirlpool WP8544771 Heating Element - AppliancePartsPros.com
Yes inside where the filter slide in.
thank you very much for your help. greatly appreciated. Best regards
stef.
