How do I replace Frigidaire part 5304538823 Oven Thermostat Temperature Control?
Brand: Frigidaire
Model Number: FFGW2426UWB
Main Symptom: Won’t turn on
What happens & when: When I turn on the bake mode the burner doesn’t come on, just the fan. I have replaced the control panel, ignitor, and temp sensor.
Someone suggested I replace part 5304538823 Oven Thermostat Temperature Control?
Where is that located and how do I replace it?
Error Code (if any): None
Parts or tests already tried: control panel, ignitor, and temp sensor replaced.
I believe that is accessed by taking the oven out and taking off the top panels. That TCO is located on the flue assembly.
Before you do that, does the broil element work? If it does then you’re looking at the gas valve 807192701, not the thermostat 5304538823.
No the electric broil element doesn’t work either.
thanks
