Hotpoint Dishwasher
The rod that is between the motor and the top of the motor is leaking.
How do I fix that?
Can I just replace the rod?
Most likely the water is coming out due to broken seals in the pump.
You can replace the seals on the old pump or replace the whole pump & motor assembly.
In both cases the dishwasher has to be removed from the cabinet.
Both parts are coming with the installation instructions.
Here are the break down diagrams for the Hotpoint dishwasher Model HDA100X-66WH
