Hotpoint dishwasher makes horrible grinding noise
I am not sure exactly how old the dishwasher is. It was in our house when we bought it 3 years ago and I haven’t ever used it because it makes this horrific, loud grinding noise when it is started. I have tried to locate a diagram to try to repair it, but can’t. Does anyone have any suggestions as to what might be causing this noise? Thank you so much!
I would be willing to bet that the FAN BLADE thats built into the motor has broken loose from the shaft of the motor, The only thing to do is replace the PUMP&MOTOR assy.:slight_smile:
Thank you. That is what I was afraid of!
