Hot burner light stays on
Light that tells you burner surface is hot stays on , on front left burner. How do you repair?
Most likely the problem is a bad infinite switch for this surface element.
  • The part number for the switch is AP3028783
Here are the break down diagrams and Replacement parts for WHIRLPOOL RF366PXYQ4 | AppliancePartsPros.com
