Honeydothis
[FONT=Arial Narrow][SIZE=4]:eek: Dryer just quit today after one load. Now all it does is click when you press the start button. Motor doesn’t run the barrel. Just clicks when you press the button. Is it my motor or a relay? Finace’s strapped tight to fis this one![/SIZE][/FONT]
[FONT=Arial Narrow][SIZE=4]Thanks for your help![/SIZE][/FONT]
check the door switch, then your circuit breakers…
