Heat is not reduced on delicate cycle.
Automatic dry (using moisture sensor) doesn’t work.
Anyone know what I need to get to fix the problems?
Thank you
Hunter
Hi Hunter
It is likely, but not certain, that your problem is in the timer, particularly given the age of the machine and the fact that you everything in this machine is built into the timer. You will have to make a decision as to whether or not you want to risk money on a new timer, or use the funds towards the purchase of a new machine, or just stay with it as it is until you are ready for a new machine.
I would check all of the thermostats first and inspect the insides of the machine for any connection or wiring problems, but if you do not find any problems, which you probably will not, you can try replacing the timer.
Here is the part.
Part Details - WHIRLPOOL Timer, part number: 3398193
Good luck and let us know what you do and how it turns out.
