Here is a real puzzle. Siemens IQ500. Matrix cleaned, but wont accept water
Brand: Siemens
Model Number:IQ500
Main Symptom: Water wont fill into Matrix
What happens & when: Runs, makes all the right sounds, hums, clicks etc. Then stops on 000. No Error codes.
Error Code (if any): none
Parts or tests already tried: Matrix cleaned exhaust water pipe cleaned and sink connection cleaned
Siemens dishwasher, model SN45M507SK. I have been troubleshooting a persistent issue where the machine fails to fill with water and aborts the wash cycle after approximately 20–30 minutes, returning to 0:00 with no error code.
Below is a clear, structured summary of the full diagnostic process and findings so far. I hope this helps your technical team quickly identify the underlying cause and advise on the most efficient next steps.
1. Initial Symptoms
  • Dishwasher powered on normally but failed to take in water.
  • The machine would drain, attempt to fill, then abort early.
  • No water entered the sump or wash chamber.
  • No error codes were displayed.
2. Actions Taken
  • Fully disassembled the left-side water matrix (heat exchanger / labyrinth system).
  • Performed extensive cleaning of the serpentine channels, float chamber, and internal pathways.
  • Removed significant internal sludge and deposits.
  • Verified that water can now pass through the previously blocked snake-shaped channel.
  • Reassembled the unit carefully and ensured all seals and hoses were correctly fitted.
3. Behaviour After Reassembly
  • The dishwasher now runs significantly longer (20–30 minutes) before aborting.
  • Multiple internal sounds are heard: pumps, valves, clicks, and shifting mechanisms.
  • Despite these attempts, no water enters the matrix or the tub.
  • The matrix remains completely dry during operation.
  • The sump remains dry.
4. Current Diagnosis Based on the behaviour, it appears that:
  • The inlet valve is opening (audible water movement), but
  • Water does not enter the matrix at all, and
  • The machine repeatedly attempts to fill before giving up.
This strongly suggests that the flow‑meter turbine (integrated into the matrix assembly) is not receiving water flow. The likely cause is a remaining blockage in the vertical inlet riser feeding the turbine chamber, even though the visible channels of the matrix have been cleaned.
Because the turbine does not spin, the control board receives zero flow pulses and shuts the inlet valve immediately, preventing the machine from filling.
5. Request for Assistance Given the extensive cleaning already performed, I would appreciate guidance on:
  • Whether Siemens recommends further cleaning of the inlet riser feeding the flow‑meter.
  • Whether the flow‑meter turbine chamber can be serviced or inspected.
  • Whether the recommended solution is to replace the entire water matrix assembly.
  • Any known service bulletins or common failure patterns for this model.
I am hoping some members may have experience with this specific failure mode and can advise on the most efficient path forward.
Thanks to all that take interest.
Nb. I am an older retiree and cannot carry the unit and drive it to the city to have it repaired. Hence, try to fix it myself. Wrote to Siemens. They were not in the least interested to advise, or help/
Kind regards, Terence
Hello Terence, if water is not going through into the heat exchanger, the water tube from the aquastop assembly can be disconnected and placed into a 2-liter/half-gallon jug or container. Once it is aimed into the container, the valve wire connection can also have meter probes secured to it and the meter set to Volts AC for testing purposes. Once this set up is complete, a cycle can be started. The valve should receive 120 Volts AC. If it is receiving proper voltage, does water enter into the container? If not, the water valve would be the likely cause of failure if there is not a kinked supply hose or a supply valve is clogged/shut off. 00673684 Prolongation | Genuine Bosch OEM In Stock
Understood. Thank you very much for your advice. :+1:
Hello William,
Sorry for the belated response. I was waiting for my hair to grow back, after pulling it all out over this dishwasher. :exploding_head: So to comment on questions and opinion. No the hoses are not kinked. I would have to research which inlet valve you mention. What I can say is that there is much staining inside the galleries. I hoped that finding and installing a new water gallery (heat exchanger?) May cure the problem. Not technical enough to do the testing you mentioned. I would call in a technicians to fix it, but i am retired, and live in the boonies. Too many narrow trails, mountains, and fiords to navigate. Most would not come out here to service. Hence I look for assistance. Thank you for responding. Terry
There should be a white hose that runs from the back of the dishwasher towards the front. The house water supply would be connecting into the side at the back. The plastic housing where the water connection from the house supply hooks in is where the inlet valve is going to be. An easy check would be disconnecting the white hose from where it connects into the dishwasher water matrix on the left side of the tub. The hose can be aimed into a 2 gallon/ 7.5 liter bucket or pot. If the dishwasher is started and a hum can be heard coming from the plastic section where the house water supply connect in, water should pass through. If not, the water valve has failed.
Hello William, Ai is now saying your advice is positive but also, has recognized another possible culprit; The Aqua Stop/ Block. Do they require replacing?. I will follow your directions. AI states that after testing as you prescribed, and if the water does not flow, then it is the Aqua Stop type 88 situated on the water line outside the machine. I know this could be accurate or not, as AI has been wrong a few times before. Thanks. here is a copy of a.i; :magnifying_glass_tilted_left: Your AquaStop is almost certainly the cause
Your evidence:
  • Bitron Type 88 markings
  • Electrical cable inside the hose
  • No water reaching the gallery
  • Matrix already cleaned
  • Machine behaves like it’s trying to fill
  • No internal leaks
  • No water entering the tub at all
This is textbook AquaStop solenoid failure or internal diaphragm loc
The aqua-stop is another name for the water valve.
