Help
my dryer will not start up. it was working fine. my light comes on inside and it turns off when i hold the switch in. breaker is good. when i set everthing and push start nothing happens except a click. anybody had this problem before?? Help :eek:
Use this tech sheet to troubleshoot it. If you cannot get it into a diagnosis mode your control board may be the problem.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10054150.pdf
