Where can I take my parts to get them tested:confused:
Need more info!!!
What parts?
Test for what?
What Model Number?
What is the problem?
etc.
Some parts supply houses will test parts for you re: heater resistance etc.
But not all places will do this.
Perhaps if you do the following you can check your own parts.
