Help
Ref Starts Right Up Runs For About 1hours Feels Cold Shuts Itself Off Comp Stop Fan Stops Lights Work But Will Not Start Back Up Even If You Leave Door Open Warm Ref Up Only Way To Start Back Up Is To Unplug For Awhile Plug Then It Will Start Right Up Like A Breaker In Ref Is Tripping Or Something Help Please Amercana 127817137
Hi.
There are two things which could cost this problem:
The cold control and defrost timer.
They both located in the control panel inside the refrigerator. Find the opening size of the dime in the control panel and use the flat screwdriver to slowly turn the defrost timer’s shaft CW until it clicks.
If the fridge starts - replace the defrost timer, if not use the screwdriver’s butt to knock at the cold control 's knob and if the fridge kicks in - replace the cold control.
The cold control WR09X10042
The defrost timer WR09X10049
Here are the breakdown diagrams and 03-Unit Parts parts for GE A3316ABSARBB - AppliancePartsPros.com
Post the results.
Simon.
