HELP! Dryer doesn't work a
We used the dryer at our old house, up until the day before we moved. We moved it, and it sat in the garage for two days. We sold it, and the new owners called stating the dryer doesn’t work at all. I supposed to go over there tonight to see what’s the problem. Any suggestions?:confused:
I was unable to get your model number to come. Possible due to the age but in general If the dryer does not run it could be a number of things including: timer, start switch, door switch, thermal fuse, high limit thermostat, cycling thermostat and motor.
The start switch, door switch, thermal fuse, high limit thermostat and cycling thermostat can all be checked for continuity (they should have continuity if not that part could be the problem)
If you have the knowledge to read wiring diagrams you can find the 2 leads from the timer that supply the power out of the timer remove the wires and set the timer to the timed cycle and you should have continuity through those 2 wires if not suspect the timer.
If you hear a loud buzzing or if you can “help” the drum start to turn it could indicate a bad motor.
