Help confirming part number for KitchenAid dishwasher
Hi, I’m pretty sure it’s the control panel–lights go on as they should but then it doesn’t start.
Having trouble figuring out if AP3775964 is the right part. thanks
Are any of lights blinking?
The part number you posted is for the control board. The control panel AP5956766
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDK01ILBS2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Hi, the lights go on as they’re supposed to. You hit the cycle button and the dry and the “start”. They all light as usual and then…nothing happens.
Check the door switch and make sure it’s engaged properly when the door is locked.
What’s the next option? Control panel? thank you!
[quote=Gene;552256]Check the door switch and make sure it’s engaged properly when the door is locked.
Gene.[/quote]
Part Details - WHIRLPOOL Electronic Control Assembly, part number: AP3775964
[QUOTE=soundtownsal;553140]What’s the next option? Control panel? thank you![/QUOTE]
Yes, it is.
thank you very much![quote=Gene;553147]Yes, it is.
Gene.[/quote]
