Brand: Bosch Model Number: SHY56A05UC/23 Main Symptom: Sump does not drain What happens & when:
Parts or tests already tried: I removed the drain pump just to be sure there was nothing blocking the impeller. All looks good. Nothing is blocking. On my work bench I connected 120V to the terminals on the pump and the pump runs fine so now I am thinking the issue is not the pump. The next suspect part is perhaps the check valve which looks to be a bear to get to. I did however poke a screwdriver into the check valve through the port where the pump is removed. I have the water feeding the dishwasher turned off under the sink but interestingly enough when I poke the check valve water squirts out. It defiantly has backpressure on it. Now I am stumped on where to look next. The check valve seems to be checking off pressure, but I really don’t know what is further down the flow path. Seems like the pump pressure is not enough to overcome the back pressure.
Hello! You’ve already done some good troubleshooting, especially removing the drain pump, checking the impeller, and confirming that the motor runs when supplied with 120 volts.
Based on what you’ve described, I would hold off on replacing the drain pump or check valve until we check the drain hose and confirm the pump is receiving power during a drain cycle.
The water squirting out when you push on the check valve is an interesting clue, but it doesn’t necessarily mean there’s excessive backpressure. It could simply be water trapped in the drain hose.
Here’s what I recommend checking next.
1. Check the drain hose for a blockage
This would be my first test.
Turn off power to the dishwasher.
Disconnect the dishwasher drain hose from the garbage disposal or sink drain connection.
Place the hose into a bucket.
Restore power and initiate a drain cycle.
What happens?
Strong water flow: The pump and dishwasher drain path are likely working. Check the garbage disposal connection or sink drain for a restriction.
Weak flow or no water: We need to determine whether the pump is operating and whether something is blocking the drain path.
If the pump runs but doesn’t move water, inspect the entire drain hose for a kink or obstruction.
2. Check the drain check valve
The check valve’s purpose is to prevent water in the drain hose from flowing backward into the dishwasher.
When you pushed on the valve and water squirted out, you may have released water trapped in the hose. That alone doesn’t indicate a defective valve.
With the power disconnected, inspect the valve to make sure it opens freely in the direction of water flow and isn’t obstructed by debris.
3. Verify voltage to the drain pump
Even though your pump runs on the workbench, we still need to confirm the dishwasher is supplying power to it.
If you’re comfortable testing live voltage:
Reinstall the drain pump and reconnect its wiring.
Set your multimeter to AC volts.
Carefully measure across the two pump supply terminals during a commanded drain cycle.
You should see approximately 120 VAC while the control is energizing the pump.
Live Power Warning: This test involves exposed electrical connections. Only perform it if you can safely access the terminals without contacting energized components.
Here’s how to interpret the results:
Test result
What it indicates
120 VAC and pump runs, but no water drains
Check for a restriction, valve problem, or weak pump
120 VAC but pump doesn’t run
Suspect the pump or its connections
No 120 VAC during a confirmed drain command
Check wiring and the control circuit
4. Don’t overlook the sink drain connection
If the dishwasher connects to a garbage disposal, make sure the disposal inlet isn’t plugged with debris. Also check that the drain hose isn’t kinked or clogged where it connects to the sink.
My recommendation
Since your Bosch SHY56A05UC/23 drain pump operates when supplied with 120 volts, I wouldn’t condemn it yet. A pump can run without a load and still fail to move water properly, but we should eliminate a blockage or electrical issue first.
One question that will help narrow this down considerably:
When you initiate a drain cycle with the pump installed, can you actually hear the drain pump running, or is it completely silent?
That will tell us whether to concentrate on the drain path or the electrical supply to the pump.
