how do I know if the heating element is bad? part number ap3094254 I’ve replaced the thermostat and cycler:confused:
Often if you remove it from the unit you will see that it is broken.
First I would check the power.
The motor uses 120 but the heating coil requires the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
Next check the heating coil using resistance.
Unplug the unit
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Also it will let you check the power.
