Brand:Kenmore
Model Number:110.95866402
Main Symptom:keeps blowing thermal fuse
What happens & when:After replacing thermal fuse the dryer will work and dry 6 or so loads then thermal fuse blows. Second time I replaced fuse I also replaced thermistor. Again dryer worked a few times the blew fuse again. Vent is clear, high limit thermostat has continuity.
Parts or tests already tried:thermal fuse; thermistor
Start by checking that the vent is a 4-inch-diameter rigid metal pipe (no plastic, vinyl, or metal-foil vent material). Check for minimal turns and length. Check to ensure the vent is clear all the way out from the blower, all the way outside. The number one cause of multiple thermal fuse failures is airflow. Next, check the wiring and element circuit for damage or shorts.
Washer Dryer Combo: Troubleshooting Common Washer Dryer Combo Problems & Solutions
Thank you for your help. Everything checked out with the vent. I ended up replacing the 2 moisture sensor bars (ordered from Appliance Parts Pros) because they were bad. After replacing I received an E1 code (it had never given a code before). I checked the thermistor again, but it checked out fine. I ended up having to change the control board. So far it has been working fine. Fingers crossed.
