Hard white soap still on dishes after wash is completed!
There is a very hard white residu on the dishes and specially glasses after the wash is completed !! It’s not the water, it’s the detergent that has not washed off and got hard due to heat of drying !!
It seem alot worse on the top rack !
I have noticed that the “collapable funnel shaped tube” that extend from the roof of the washer into the extending spraying arm is missing !!
I’m not sure if you know what part I’m talking about because I don’t see the part number in the diagram !!
It’s a colapsable tube that extends from the inner part of the top nozzel into the receiving end of the spray arm !! So it connects and delivers the water from the roof nozzel to the spray arm !!
Anyways… I saw that part once extending out once before, and now it’s not there any more !! As if it has desolved !!
Pleae tell me the part number so I can order it !!
I would appreciate if you could contact me ! (773) 255-9944
Mike
I just thought of something !!
The extention funnel tube that I’m looking for, is it inside the nozzel and not a seperate part !?!? so do I just need a new Nozzel !!??!
