Glasstop stove F1 & F3, beeping, beeping
Brand:Maytag
**Model Number:**MES5770AAB
Main Symptom:F1 F3 beeping shuts off
What happens & when:It reaches temperature after using the top burners
Error Code (if any):F1, F3
Parts or tests already tried:Replaced oven temperature sensor and connections already, no good
Sorry I did not see where to enter text about the problem.
I have an older Maytag glasstop stove (MES5770AAB).
The stove top burners work fine. And the oven works some of the time. But if the top burners are used, and then the stove, sometimes it gets up to temperature, then flashes F1 or F3, and beeps until it cools off.
I’ve changed out the oven temperature sensor with a new one, and its still happening.
At first I thought it was the connection wires- there are two, and because the plastic connectors didn’t fit (I stupidly missed the adapter piece in the bottom of the box), I had used wire caps and screwed on the two contact points.
AI (Google Gemini) went on about the wire caps not being true heat compatible wirecaps. So I went back and stripped the wires clean, and connected them with ceramic oven wirecaps, rated for 600’F. Then for good measure, I wrapped the caps in high temperature silicone tape. I then made sure none of the wires behind the oven were touching the back metal panel.
Tried the stove with the back off. IT WORKED.
Tried the top burners, then the stove. IT WORKED.
Put the back panel back on, pushed it back in the corner, and ran the stove one more time
F1, F3, beeping still.
Unplugged, plugged it back in. Ran the stove.
F1, F3, beeping again after it gets up to temperature.
I’m defeated. What in the world could this be? It seems a simple thing but I can’t figure it out for anything. Has anyone seen this happen before.
It sounds like the main control may be getting too warm and failing. Since the back panel being removed allows the oven to work properly, is there anything that sits on top of the oven back that might not allow heat to dissipate? There should be a vent at the back that would disperse heat unless something was sitting on top of it.
