Glasses not getting clean
My dishwasher is not getting the glasses clean, it seems to be progressively getting worse. I timed the filling of the dishwasher and it filled for over 1 1/2 minutes and still was not full. Any suggestions?
Since the unit is not filling correctly the screen filter on the inlet side of the water valve is probably partially plugged.
Remove the valve and check/clean it.
Do not remove it as it is there to keep crud out of the valve which could hold it open and cause a flood.
