GFW550SSN5WW stops running a few minutes into the cycle
Brand: GE
Model Number: GFW550SSN5WW
Main Symptom: Shuts off mid-cycle
What happens & when: When a cycle is started, the washer will proceed as expected. Water fills the tub, drum spins for a few minutes, then it shuts off every time. I can get the tub to drain when enough water is inside. There is also a ticking sound coming from the main control board area.
Error Code (if any): 33, 92, 66, 38, 40, and two others (1 additional for vent damper and 1 for the pressure sensor).
Parts or tests already tried: Attempted T10 and T24 with no success.
Sounds like an inverter board is going out. Unplug for about 10 minutes to let the codes reset and try it again. Remove the rear panel and inspect the inverter board and wires to make sure none are broken. It could also be the water pump is going out. That is cheap to replace but it might not be your main issue.
Tried again after unplugging. After starting the cycle, nothing happens and the unit shuts off. Only codes I get are related to the inverter and vent damper. The clicking is gone as well.
