Ge
I’m looking at replacing the small black seals in the bottom of the dishwasher. Do these seals simply slide out for replacement? Here are the part numbers AP2038859 AP2038860. Is this a simple task?
Sam
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Very simple to replace just pull the old ones out and press the new ones in. I got a question are you replacing them because the dishwasher is leaking? If so I would bet that this will not fix the problem. My guess would be a soap problem or it’s leaking through the door. although if it does fix your problem great!![/FONT][/COLOR][/SIZE]
No leaks. Those tub seals are just deteriorating and I thought I would be proactive instead of waiting for something bad to happen.
