Ge washer model gtw680bsj5ws won't spin
Brand: GE
Model Number: gtw680bsj5ws
Main Symptom: won’t spin
What happens & when: at the start of the cycle while going through the checks it stops. Flashes lid and end. I installed a new lid lock that i purchased from appliance parts pro. It worked for three washes and started doing the same thing. Diagnostic #13 (the lid lock diagnostic) fails to lock the lid. I have checked the wiring and plugs all are still attatched. Part seems bad but i needed to send this for a warranty replacement on the part.
Error Code (if any): lid lock
I’m having the same model and the same issue with my machine, Will not going into spin cycle. I’ve replaced all the "usual suspect"parts, including main board assy, Lid switch kit, shift assembly, and the rotation sensor that mounts on the main motor. I checked the pressure tube to make sure it was clear by blowing through it. I checked with a meter, the board never powers the motor, so I don’t suspect a the motor is bad. No mechanical problems I can find. The belt, pulleys and other mechanical parts between the main motor and drum are all good. You can rotate the main pulley by hand, the drum turns. This is extremely frustrating. This machine was expensive and is only about 4 or 5 years old. I’ll never buy a GE appliance after this ordeal.
Is the model # the same?
Yes, that is the model I have.
I can certainly understand your frustration, especially after replacing so many parts and still having the same problem with your GE washer, model GTW680BSJ5WS. You’ve already done quite a bit of troubleshooting, and the fact that you’re not seeing voltage going to the motor is an important clue.
Before spending any more money on parts, I’d like to narrow down what’s preventing the washer from entering the spin cycle.
1. Check for stored error codes
The first thing I’d recommend is checking the washer’s service diagnostics for any stored error codes. Even though you’ve replaced the main control board, lid lock, shift assembly, and speed sensor, the washer may still be detecting a condition that’s preventing it from spinning.
Pay particular attention to any codes related to the lid lock, water level, motor, or mode shifter.
2. Check the water-level pressure system
You mentioned blowing through the pressure hose to make sure it was clear, which was a good first step. However, I’d also check the air chamber where that hose connects to the outer tub.
Sometimes detergent residue or buildup can interfere with the pressure reading, even when the hose itself is clear.
The control needs to recognize that the tub is empty before allowing the washer to reach high-speed spin.
3. Run the diagnostic spin test
I’d also recommend running the washer’s spin test through service diagnostics.
This is especially helpful because it allows us to see whether the control can operate the motor independently of a normal wash cycle.
Watch for three things:
  1. Does the lid lock properly?
  2. Does the shift assembly attempt to engage?
  3. Does the motor hum, try to turn, or remain completely silent?
If the lid locks but the motor never attempts to run, that gives us a better direction for electrical testing.
4. Check the motor wiring and capacitor
Even though you’re not seeing voltage at the motor, I wouldn’t completely rule out the motor circuit just yet.
With the washer unplugged, I’d recommend checking the wiring harness between the control board and motor for continuity. Pay close attention to loose connections, damaged wires, or terminals that may have overheated.
I’d also check the motor capacitor. A failed capacitor can prevent the motor from starting, although it wouldn’t normally explain a complete lack of commanded voltage.
Safety note: Any live voltage testing should be performed carefully, since you’re working around 120 volts. Be sure the washer is actually commanding the motor to run when taking those measurements.
5. Verify the replacement control board
Since you’ve already replaced the main control board, it’s worth verifying that the replacement is the correct part and that its personality configuration matches your washer.
An incorrect configuration can sometimes cause unexpected operating problems.
Here’s what I’d like to know next
Rather than having you replace another part, I’d like to ask you two questions.
First, does the washer agitate normally during the wash portion of the cycle, or have you lost both agitation and spin?
Second, when you attempt a spin cycle, does the lid lock and the drain pump run, or does the machine simply sit there without doing anything?
Those two details will tell us quite a bit about whether the control is preventing the motor from running or whether we need to focus on the motor circuit itself.
You’ve already put a lot of time and money into this repair, so I’d really like to help you pinpoint the problem before you spend another dollar on parts.
Here is what I found troubleshooting the motor itself:
See the diagram below. I checked the motor windings as follows.
I unpluged J511 from the main board. I measured PIN 3, (SWITCHED LINE) across both Pins 1 (CCW/Spin Winding) and Pin 2 (CW Winding) and it measured OPEN. No connection between either motor coils.
I then mesured across pins 1 and 2 and it reads about 6 ohms. The diagram indicates there is an overload fuse (thermal fuse) on the SWITCHED LINE connection within the motor. If this fuse in OPEN, what would be the result? Would the motor appear dead? If this line reads OPEN to the main board, will it even attempt to power the motor? When I checked for power to the motor when I tested the first time I measured across the start cap. As I tried to run the spin cycle, I always got 0V AC across the cap. (Yes I did test the cap, it reads 60 Micro Farad) But that was with the original main board assembly.
I must decide to continue with trying to repair this washer of dropping $600+ dollars on a new one. Wife is getting very impatient.
Much Thanks
Thanks for sending the wiring diagram! This helps quite a bit, and I can see exactly what you’re describing.
Looking at the diagram for your GE GTW680BSJ5WS, I agree that the motor’s internal overload protector is a strong suspect.
Here’s what stands out
The diagram shows that the switched line from J511 Pin 3 goes through the motor’s internal overload protector before reaching the windings.
Your readings were:
  • Pin 3 to Pin 1: OPEN
  • Pin 3 to Pin 2: OPEN
  • Pin 1 to Pin 2: Approximately 6 ohms
The diagram specifies approximately 2.8–4.2 ohms for the motor winding circuit. Your 6-ohm reading between Pins 1 and 2 makes sense because you’re measuring through both windings in series.
Since neither winding has continuity back to Pin 3, the problem appears to be in the common connection shared by both windings.
Would an open overload protector prevent the motor from running?
Absolutely. If that protector is open, neither winding can receive current through the common connection. The motor won’t agitate or spin, even if the control board is working properly.
The control board may still attempt to energize the motor, but it cannot make the motor turn with that circuit open.
One more important detail
Your earlier measurement of 0 VAC across the 60 µF capacitor doesn’t necessarily indicate a defective control board. Measuring across the capacitor isn’t the same as checking whether the motor is receiving its switched-line voltage.
I wouldn’t replace any more electronic components until we’ve confirmed the motor resistance directly at its connector.
My question: When you measured OPEN between J511 Pin 3 and Pins 1 and 2, was the motor completely cool, and had the washer been unplugged for a while?
If so, and the same readings are confirmed directly at the motor, I would be strongly leaning toward a failed motor assembly rather than another control board.
OK Guys. I pulled the motor and hoped it was a bad connection or wire issue. NOPE. It is the motor for sure. I ordered the motor this afternoon WH49X25375 (AP6032787). I’ll report back after it’s installed. And a heads up. The thermal fuse is part of the motor coil, not something attached to the motor frame that could be replaced. You MUST replace the motor if the thermal fuse opens.
Thanks all.
CONCLUSION:
The motor didn’t fix it. I installed the motor and put it all back together. Upon first trying it, the washer made a loud humming noise I had not heard before. It sounded like the motor was bound up. I quickly shut the washer off. I tried a couple different settings and got the same results. Upon the 3rd or 4th time trying it, it went back to doing the exact same thing as before I replaced the motor. I suspect the thermal fuse in the motor opened. The drum spins freely, the pulleys and belt are clean and in good condition. At this point I have $600 invested in this attempted repair. The price of replacing this washing machine with one of the same capicity. The following day we did exactly that and purchased a Maytag (made by Whirlpool).
If there is a moral to this story it is this; TRUST your gut feeling about things like this. Aftering reading about all the common faults and failure and replacing the first round of parts that didn’t resolve the issue, my instinct was to put the brakes on trying to fix it. But I continued throwing money at it. Almost like a gambler hoping his number will finally hit. I knew better but I didn’t trust my instinct. I’m not assigning blame to anyone but myself. AppliancePartsPros.com was my friend and ally during this endeavour.
Other possabilities,
Bad start cap? Tested it. It read 60 micro farad.
Transmision locked up? The drum turns smoothly. The shift assembly was replaced also. Overloaded? Nothing in the drum when testing.
Insufficent AC voltage from outlet? Check that. It’s fine.
Any other idea? I don’t want to junk this washer. I would like to figure this issue out.
The GE washer and dryer are a matched set and I intended on them going with the house when we sell it.
