GE Washer GFW550SSN5WW no power
Brand: GE
Model Number: GFW550SSN5WW
Main Symptom: No power
I started washing my clothes and the when I came back it had no power to the machine, it was full of water and the door was locked shut. I drained the water, filter was clean minus a couple of hairs caught in the filter (I regularly clean it) I manually opened the door I verified 120v coming from the outlet and verified 120v at the board but am not receiving any power anywhere else.
I ordered a new board, received it, plugged it back in and still nothing, I re-verfied the outlet and power to the board but I am not receiving power anywhere else. I checked all the wires, they look good. Customer service said to post here. Did I received a bad board or is there something else going on? When I plugged it in nothing happened no pop, smoke, light just nothing.
Thank you in advance.
Unlikely to be a bad board out-of-the-box doing the exact same thing. What was the part # that was ordered? Did you check for power at the drain pump? Sometimes a bad drain pump can cause a situation like this.
Thank you for the response. I ordered WH22X38697 from the site and verified it was correct. I have no power anywhere else. It just stops at the board.
Did it allow you to program the personality code or was it unresponsive to that as well? I’ve attached the instruction sheet for programming, just in case.
GFW510SCN 0694P00000Z0PFoQAN.pdf (177.9 KB)
I cannot power on the unit at all. There is no display, no sound. Nothing
Not powering on at all makes me wonder about the user interface boards WH22X34938 in the console.
At those UI boards you should have a 4-wire connector with black, red, blue, and yellow wires. Check for DC voltage from black to red.
These are the reading I get.
Measurement location Recorded value
Electrical outlet 122 VAC
Incoming power cord connection 120 VAC
Drain pump 20.3 Ω
Meter probes held together 0.2 Ω
Brown pump wire, end-to-end 0.4 Ω
Black pump wire, end-to-end 0.4 Ω
Brown pump wire to chassis ground OL
Black pump wire to chassis ground OL
Between brown and black pump wires OL
Door lock, blue–brown, latch released OL
Door lock, blue–brown, latch engaged 123.1–124 Ω
Door lock, red–blue OL
Door lock, red–brown OL
Control board Q553, outer terminals 14.8 Ω
Ah, forgot about this, is there an LED on the main board that is lit or flashing? If it isn’t then the issue should actually be with that main board, in which case you can call our customer service team at 1-877-477-7278 to get that swapped out as a bad part.
