GE Triton Not Draining and in endless loop
My GE Triton GSD5560G02SS is showing similar symptoms to this thread:
http://forum.appliancepartspros.com/dishwasher-repair/92156-ge-dishwasher-not-draining-all-way.html
The water does not drain and the wash cycle never stops. The front lights cycle through and starts over.
I checked the piston and nut and they look fine. I checked the drain hose and it is not blocked. My guess is that the drain pump and/or the electrics (controller assembly?) are broken.
Should I get both parts and try to replace the pump to see if it resolves the issue? Or is is it definitely one or the other?
Thanks in advance for your assistance.
Ali[LEFT]
[/LEFT]
