GE Triton leak
I have a GE Triton XL dishwasher that is leaking. I have figured out the bottom seal is broken, but I do not believe the seal has anything to do with the dishwasher not draining. Recently, within the last two month I pulled the drain tube out of the disposal to look for some build up but the hose was clear. I am having a hard time removing the parts in the bottom of the dishwasher to check for any other blockage but would rather do that in order to not have to buy another part. I feel like the dishwasher not draining and the leaking all started happening at the same time but I don’t know why that would be or why the two would be connected. Can anyone help me please?
[SIZE=3][COLOR=#000000][FONT=Times New Roman]There is a main wash pump directly under the wash arm and to the left and more to the back of that main pump you should see the drain pump. This drain pump may be clogged up causing your dishwasher not to pump out. Remove all the water then remove the pump and check for blockages. If that is not blocked there is a hose that runs from the pump up the side of the dishwasher then to the drain hose check to see if either of them is clogged. [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman][/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Dishwasher Repair Guide[/FONT][/COLOR][/SIZE]
