GE Triton Dishwasher
Hello,
I have a GE Triton Dishwasher that will drain, I hear and fell it drain, but will not drain the water completely out. It will leave water up to the elements. I have checked the fine filter at the very back, bottom of the dishwasher and found nothing. I checked the piston and nut assembly and it looked perfectly fine. I took apart the sump and found nothing down int he hole. It was very dirty water though.
Any ideas?
Thanks,
Joe
A model number may help others help you.
Sorry about that the model number is GSD5560G01SS
Here are the parts
Motor - pump mechanism replacement parts for General Electric GSD5560G01SS Dishwasher | AppliancePartsPros.com
Can you feel/hear the drain pump running?
Disconnect the drain hose from the house plumbing.
Often it will clog where the hose goes over the fitting.
You could try draining it into a pail to eliminate a house plumbing clog as the cause. Just be sure to hold the drain hose securely in the pail and put a towel over it’s top, unless you want a shower.
