GE Stove top JP989BK1BB right front burner won't turn on but getting power to it
Brand: GE
Model Number:JP989BK1BB
Main Symptom:right front burner.
What happens & when: Replaced the burner with a new burner from APP and an infinite switch from APP as well. Seeing power to “small box attached to burner where the wiring clips in” but the burner is still not coming on. Did this with the old burner and the new burner. both show power getting all the way to the burner, just not firing on.
Parts or tests already tried: replaced burner and infinite switch. triple checked the wiring . no sign of wires being melted or breached. Volt detector shows power going to all but one terminal at the burner. Using a voltage meter, i get voltage to all terminals from the H terminal but no voltage indication when checking from the S terminal .
could it be the new infinite switch is faulty? i tested with the voltage meter with both burners and they indicated the same symptoms.
Yes, it’s possible the new infinite switch is defective, but since you’ve tried both the original and replacement burners with the same results, I’d like to verify the voltage before replacing anything else.
One important thing to know is that detecting voltage at the burner doesn’t necessarily mean it’s receiving the full 240 volts needed to heat.
The small box attached to the burner is likely the terminal connection area for the heating element and its temperature-limiting components.
Here’s what I’d check next:
1. Check the voltage across the burner. With the burner switched to HIGH, measure AC voltage directly across the two heating-element supply terminals. You should typically see approximately 240 VAC. Measuring from one terminal to ground can be misleading.
2. Check the infinite switch. With the switch on HIGH, verify approximately 240 VAC across L1 and L2 at the switch. Then check the switched output circuit according to the switch’s terminal diagram. If the correct supply voltage is present but the switch isn’t delivering power, the switch or its wiring could be the problem.
3. Check the burner and limiter. Disconnect power at the breaker and verify it’s off. Disconnect the element leads and check resistance across the heating element. An open reading indicates a broken circuit. The temperature limiter could also be interrupting power, depending on how this particular burner is wired.
Important: These are live 240-volt tests. Only perform them if you’re comfortable working around energized electrical connections. Otherwise, have a qualified technician perform them.
Also, the S terminal may be part of the hot-surface indicator circuit, rather than the main heating circuit. Not getting a voltage reading from S doesn’t automatically indicate a defective burner or switch.
One question that will help narrow this down:
When you checked voltage at the burner, were you measuring between two burner terminals with your multimeter set to AC volts, or were you using a noncontact voltage detector?
That distinction will help us determine whether we’re dealing with a faulty switch, an open limiter, or a missing leg of the 240-volt supply.
