My GE Monogram side by side built in refrigerator model # ZISS480DRBS never gets above freezing - mostly around 28 degrees. Doesn’t respond much at all to temp settings. Freezer works perfectly. I replaced the fridge temp sensor without improvement.
Text conversation with this site’s parts tech who said it is Main Control Board Assembly, part # AP3885943. On searching other sites, what sounds like same problem diagnosed as Damper Control Assembly (door stuck open?). Would prefer ordering the correct solution. Any suggestions as to tracking down the problem?
